Shuts off after driving for few minutes
2011 OPEL CORSA
185,223 MILES • 1.4L • 4 CYL • 2WD • MANUAL
MOKOTEDIEK
  • 5 POSTS
Opel Corsa cuts after driving for few minutes when cold and have to wait for it to cool down before it can start again. Car was diagnosed and indicated crankshaft sensor and oxygen sensor had not working properly then we replaced them but still giving the same problem. What could be the problem sincewll it's not solved??
Sep 8, 2021 at 4:11 AM
SQM
  • 6,383 POSTS
This issue could be due to a faulty coolant temperature sensor.
If the engine coolant temperature sensor sends incorrect data to the ECM the engine will not start. It can send a signal that the engine is 'too hot' to start, which will trigger a no start issue.
Whenever the engine does not start, does it crank over? Or when you try to start it it makes no noise?
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
Let me know what you got.
Sep 9, 2021 at 12:55 AM
MOKOTEDIEK
  • 5 POSTS
Makes noise and does not crank.
Sep 9, 2021 at 3:24 PM
SQM
  • 6,383 POSTS
Is your check engine light illuminated? Any codes?
Sep 10, 2021 at 2:49 AM
MOKOTEDIEK
  • 5 POSTS
It did show crank sensor and oxygen sensor after replacing no codes but still does the same.
Sep 10, 2021 at 6:37 AM
SQM
  • 6,383 POSTS
Since you have to wait before restarting, it suggest that the issue is temperature related. As if the coolant temperature sensor is faulty it can trigger a no start due to the computer thinking the engine is 'too hot'.
Sep 10, 2021 at 6:41 AM
MOKOTEDIEK
  • 5 POSTS
So should I replace the temperature sensor and see if issue resolved?
Sep 10, 2021 at 4:35 PM
SQM
  • 6,383 POSTS
Ideally you want to test the sensor. Check the resistance between the pins of the sensor.
Since this is a euro vehicle I do not have the specifications for the resistance.
Typically for coolant temperature sensors if the internal resistance is out of the specification range it is a bad sensor.
Sep 11, 2021 at 12:14 PM
MOKOTEDIEK
  • 5 POSTS
Okay, great. will get back to you.
Sep 11, 2021 at 3:57 PM
SQM
  • 6,383 POSTS
Sounds good.
Sep 12, 2021 at 2:54 AM
