2007 Opel Corsa The secondary mileage not reset ...
2007 OPEL CORSA
13,000 MILES • 4 CYL • FWD • MANUAL
JOHANES
Corsa D 1.3 CDTI, 75 hp, 5 doors. The time is not reset the secondary mileage (middle row). We must mention that I had a little tinker intervention which had disconnected the negative terminal. After solving the problem I noticed that the first two lines of CB screen showed that had not (two fixed values, which do not change). CB I reset by pressing the button longer and have reset both lines. Then I noticed that pressing the button a little longer to power windows, do not continue to fall if we finger on the button. I have reset once or twice and have returned. Today, trying again windows, the passenger had the same problem, while on the driver was ok. CB and I tried to reset resets only the first line, the mileage remains unchanged. I tried several times, with longer or shorter durations of tightness. How to solve the problem? Thanks!
Oct 15, 2009 at 10:20 AM
DAVE H
  • 13,384 POSTS
Take the vehicle to a dealer it is still under warrrenty !!
Oct 20, 2009 at 8:37 PM
