2004 Opel Corsa sounds are coming when applying brakes
STILOMAX
Brakes problem
2004 Opel Corsa 4 cyl Front Wheel Drive Manual 9km/li miles
helo sir ... i own 2004 model opel corsaGSI petrol with 1.4cc engine . the problem is when applying brakes on brake pedal ,sqees sounds are coming from front wheels, and also my car pick up is not good like before..plz suggest .
thank you
May 18, 2010 at 7:32 AM
  • 31,937 POSTS
Hi there,
The squeal will be glazed up pads and rotors, have the rotors machined and fit good quality pads, cheap pads are full of resin and this will cause the squeal, as for the other problem start with a full tune up, this often fixes minor performance problems.
mark (mhpautos)
May 18, 2010 at 10:38 AM
