Wont start, no diesel at filter, pressurized tank and pushed diesel to filter it now start but cut out almost immediatley, please help
Friday, July 31st, 2009 AT 2:18 AM
MECHANIC
Hi there,
crack the injector lines at the fuel injectors and crank over in short bursts 10-15 sec watch for fuel dribbling out, this will bleed air from the lines, nip up connectors and start, see how you go.
Mark (mhpautos)
Friday, July 31st, 2009 AT 6:27 AM
DAVE H
MECHANIC
Hope you don't mind me adding 2 penniese worth !!
The immoboliser cuts fuel injector function on this vehicle and reset's itself after 30 seconds of ignition being in the OFF position (even with the key in)...try locking and unlocking the doors with the remote .. the immoboliser may be killing the fuel supply to injectors !!
