2001 Opel Corsa CHECK ENGINE LIGHT FLICKERS ON IGNITION
SHEPTRONIK
Computer problem
2001 Opel Corsa 4 cyl Two Wheel Drive Manual
WHEN KEY IS INSERTED AND TURNED ON, CHECK ENGINE LIGHT STARTS TO FLICKER. NO PULSE TO THE INJECTORS BUT IGNITION IS ACTIVE.
Jun 13, 2009 at 9:26 AM
DAVE H
  • 13,383 POSTS
sounds like the vehicle is immobolised ...
Jun 16, 2009 at 10:29 PM
FAROOQ007
CHECK ENGINE LIGHT STARTS TO FLICKER due to battery is over charging. Your battery is over charging due to failure of cut out of alternator. Replace the cut out with new one. Your problem will be solved.
Farooq
Sr. Engineer
Jul 22, 2013 at 1:15 PM
