1998 Opel Corsa Ignition Switch or Barrel and key
THURSIA
Electrical problem
1998 Opel Corsa
I started my Corsa and nothing happened. The lights just kepts for the battery,fuel and other lights in that category just stayed on. Turned the key to switch of but nothing happened. Lights stayed on. Had to disconnect battery for it to turn off. Found out that the pin from the barrel and key that fits into the ignition switch broke off. Can this be bought seperate or do I need to replace the entire barrel and key. But this new key will then not fit on my doors. Have to use two sets of keys than.
Apr 28, 2010 at 9:24 PM
DAVE H
  • 13,383 POSTS
you will need a new key an barrel and have to use 2 key's i'm afraid
Apr 29, 2010 at 8:33 PM
THURSIA
Can I have it welded back on until I can have the repair done so that I can use the car?
Apr 29, 2010 at 9:19 PM
