2006 Opel Astra clutch slave cylinder
SACHARVEY
Engine Mechanical problem
2006 Opel Astra 4 cyl Two Wheel Drive Manual
on the asta 2.2l 16v with the release bearing assembly inside the gearbox. what is the correct method to bleed this system
May 11, 2009 at 12:46 AM
DAVE H
  • 13,383 POSTS
you cannot bleed the slave cylinder it needs to be replaced if you suspect a fault !!
May 19, 2009 at 10:38 PM
