2001 Opel Astra WATER CIRCULATION
2001 OPEL ASTRA
105,000 MILES • 4 CYL • FWD • MANUAL
GIORGOS1104
HALLO!
A HAVE AN ASTRA G 1.4 AND I HAVE PROBLEM WITH THE WATER CIRCULATION.
I HAVE ALLREADY CHANGE THE THERMOSTAT AND THE RADIATOR BECAUSE THEY CRACK BUT THE PROBLEM IS THAT THE WATER IS NOT MAKING CIRCULATION AS IT SHOULD BE.ONLY IF I ACCELERATE!<>.
PLEASE HELP...
Nov 16, 2008 at 7:50 AM
  • 31,937 POSTS
Hi there,
If you have little or poor water recirculation, it will be a faulty thermostat, faulty water pump, or blocked radiator, as you have done all, you will have to make suer that on is not faulty, start with the thermostat again, remove and run engine if you have good flow, that is the problem.
Mark (mhpautos)
Nov 16, 2008 at 8:14 AM
