2000 Opel Astra Car Problem
EUGENE REBULADO
Engine Mechanical problem
2000 Opel Astra 6 cyl Two Wheel Drive Automatic 120K miles
My car once get started it wont run continously and shut down after a few seconds
Feb 26, 2010 at 12:56 PM
  • 31,937 POSTS
Hi there,
If it is starting and then shutting down, it could be a fuel related problem, i would first have the fuel pressure checked while on start up and see if you are loosing fuel pressure, if fuel pressure is OK do a scan and check for any unresolved fault codes that can relate to an ignition or engine management problem, start here.
mark (mhpautos)
Feb 26, 2010 at 1:48 PM
