1997 Opel Astra poor fuel economy
1997 OPEL ASTRA
45,000 MILES • 4 CYL • FWD • AUTOMATIC
FOUND1ST
i have opel astra 1.8i 16v and it consumpt 13.8 l/100km which is too much consumption for 1.8 echo tec xel type motor knowning that it should consumpt 8.4 l/100 according to the manufacture reports not missing that there are poor tourk
Feb 21, 2008 at 7:01 AM
OPEL PARTS GREECE
  • 131 POSTS
[quote:d4abf3769f="found1st"]Engine Performance problem
1997 Opel Astra 4 cyl Front Wheel Drive Automatic 45000 miles
i have opel astra 1.8i 16v and it consumpt 13.8 l/100km which is too much consumption for 1.8 echo tec xel type motor knowning that it should consumpt 8.4 l/100 according to the manufacture reports not missing that there are poor tourk[/quote:d4abf3769f]
Injectors are clean?
catalytic sensor?
C18XE,X18XE,C18XEL PETROL ENGINES
Which type is yours?
As for do it yourself repair i would suggest to be adviced with opel repair software (03/2008) or autodata with 135 euros each
OPEL PARTS GREECE
E-mail: alpharm@otenet.gr
Online: Opelparts@hotmail.com
Skype: Opelparts
May 8, 2008 at 6:33 PM
FOUND1ST
MY ASTRA IS X18XE
SO HELP PLEASE
May 19, 2008 at 1:43 AM
OPEL PARTS GREECE
  • 131 POSTS
[quote:8a4803d2a9="found1st"]MY ASTRA IS X18XE
SO HELP PLEASE[/quote:8a4803d2a9]
Complaint: Hesitation while driving around between 40 - 80 km/h with constant speed. While accelerating the engine hesitates up to the 3000 RPM. Also during deceleration the engine hesitates. Above 120 km/h there are no driving problems. Sometimes DTC P0400 or P1405 is set.
Cause: Faulty PPS signal (Valve Position Sensor).
Complaint: Poor idling, Engine stalls.
Cause: Sticky idle air control valve caused by oil vapor.
OPEL PARTS GREECE
Skype: Opelparts
May 19, 2008 at 3:10 AM
