1996 Opel Astra brocken rocker arms in camshaft
1996 OPEL ASTRA
180,000 MILES • 4 CYL • 2WD • MANUAL
SPEAKEASY
three rocker arms in my camshaft need to be replaced, but i don't know if the valves are also damaged, how do i find out?
Jan 30, 2008 at 12:01 AM
OPEL PARTS GREECE
  • 131 POSTS
[quote:dffe320144="speakeasy"]Engine problem
1996 Opel Astra 4 cyl Two Wheel Drive Manual 180000 miles
three rocker arms in my camshaft need to be replaced, but i don't know if the valves are also damaged, how do i find out?[/quote:dffe320144]
Usually at 80% none valve is damaged.
You are able to find that out with cylinder pressure check!
As for do it yourdelf repair i would suggest to be adviced with opel repair software or autodata with 135 euros each
OPEL PARTS GREECE
E-mail: alpharm@otenet.gr
Online: Opelparts@hotmail.com
Skype: Opelparts
May 8, 2008 at 6:41 PM
