1993 Opel Astra No Spark
BLACKEB
Electrical problem
1993 Opel Astra 4 cyl Two Wheel Drive Manual
I am driving a 1993 Opel Astra 160i Replace the module box and the ignition coil still no spark on the plugs. Also checked the timing belt to make sure the Dis/Rotar is turning. What can be the problem.
Thanks
Eben
Dec 28, 2009 at 12:42 AM
BLACKOP555
  • 10,386 POSTS
are you getting spark to the distributor cap right in the middle or not? how are you testing for spark. are you properly making sure that the spark tester is hooked to a good clean ground?
get back to me
Dec 28, 2009 at 9:13 AM
