Engine is not starting
200,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
JASONOLI
Evening please help what could be the problem car was driving fine nxt morning this happened Feul pump not coming on , no spark ,no injector pulse . Was told its computer box is this true
Dec 6, 2019 at 2:16 AM
  • 55,732 POSTS
It sounds like the ignition switch has gone bad. Lets see if the er is power at the ignition coil with the key on positive side. Please use this guide to show you how to use a test light:
Dec 8, 2019 at 5:40 AM
