Engine will only start and idle rough with the oil cap off
160,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SHAWNA POOLEY
If I put the oil cap on while running it shuts off the engine.
Please help?
Mar 18, 2021 at 4:40 AM
More then likely the PCV valve is clogged so we need to start with replacing this.
Here is a guide that helps with this issue if this is not it but the fact that the oil cap being removed makes a difference makes me pretty confident that this is the issue:
https://www.2carpros.com/articles/stall-at-idle
Below are the instructions that will show where this is and how to replace it.
Let me know what you find after this and we can go from there. Thanks
Mar 19, 2021 at 2:13 AM
