Only left front turn signal not working
120,090 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MRBINGO39
Can't get front left turn signal to work. changed bulb. can't get power to light but fog light fine and all other lights fine.
Sep 24, 2020 at 1:41 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you are having a wiring issue. You will need to check for a bad, loose, corroded , melted, or otherwise defective connection. I would also check to see if you are having a good ground connection. Here is a tutorial showing how to check wiring:
I've attached a exterior lighting wiring diagram for your vehicle below. I've cut the picture into 2 pieces so you can view larger. Hope this helps and let me know if you have any further questions on this issue. Thanks for using 2CarPros.
Sep 25, 2020 at 8:50 AM
