Transmission only has reverse
100 MILES • 6 CYL • 2WD • AUTOMATIC
BUD42069
Replace the driver side CV joint was the wrong one. took it to a shop they replaced it with the right one. put a new seal in and it only has reverse, it will not go into any other gear. makes no extra noises and it kind of acts like it wants to go into gear but it doesn't but it has a strong reverse.
Jul 17, 2019 at 1:09 PM
Good morning,
Is the check engine light on with any transmission codes?
Make sure you have sufficient fluid on the dipstick.
If all that is good, you have an internal failure in the transmission. The forward clutches sound like they have failed.
Jul 17, 2019 at 7:39 PM
