Engine only firing on two cylinders
115,000 MILES
ANGELA GRESHAM
It's only firing on 2 cylinders. Replaced almost everything. Plugs, wires, battery, alternator, ECM.
Jun 16, 2021 at 9:18 AM
  • 110,248 POSTS
Did this happen all at once? Have you scanned for diagnostic trouble codes? Here is a quick video showing how that is done:
https://youtu.be/YV3TRZwer8k
If you have replaced everything, then we could have a fuel injector problem or engine compression issue. Here are two links that explain how to check both:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Also, let me know if you have checked fuel pressure and for a plugged catalytic converter.
Jun 17, 2021 at 3:40 PM
