Only drivers when winter mode is enabled
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
GRANITEGUY
When I start the car it ideas high, but goes all the way down until it stalls, unless I keep foot on gas. I try to take off and regular drive it won't move if I enable the winter mode little bit slower but it works fine. please let me know what I need to fix or replace.
Oct 14, 2019 at 1:22 PM
Good morning,
Have the vacuum system tested for any leaks. If you have a major leak such as the PCV or the brake booster it will cause this issue.
Is the check engine light on? If it is, do you know the code for the area of failure?
I posted a guide for some checks for shutting off.
https://www.2carpros.com/articles/engine-stalls
Oct 14, 2019 at 8:16 PM
