One tire size on both front tires and a different tire size on both back tires?
2021 NISSAN ROUGE HYBRID
70,000 MILES • 4WD • AUTOMATIC
LAURENBRUCE7
I bought the car used last year and the original tires that were supposed to come on it from the factory where 21565r60 when I went to change the tires out, I realize that enterprise had put on 21560r70 on all four tires. Now the back four tires are still in good condition and the front are not. But I want to go back to the original tires that were supposed to come on the vehicle, so I bought two 21565r60 to put on both front tires. Will this be a problem that there is one size on both of the front tires and one size on both of the back tires temporarily until I can get them all back to the factory standard tires.
May 1, 2025 at 12:22 AM
  • 55,433 POSTS
Yep, you can't have that, the tires must be the same size, or it will create issues for the ABS and traction control systems. Depending on the rim you will need:
S Trim: 225/65R17
SV Trim: 235/60R18
SL and Platinum Trims: 235/55R19
Let us know if you need anything else.
May 1, 2025 at 4:37 AM
