One side of the brake lights are dim
156,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
HERKING3416
Whenever i hit my brakes the passenger side brake light is dim.
Mar 25, 2018 at 1:27 PM
HARRY P
  • 2,292 POSTS
This generally happens when the ground is loose or corroded. I would redo the ground wire entirely, by cutting out the old and running a new ground to the frame or some other grounding point.
Mar 25, 2018 at 8:36 PM
