If you want to remove it to check the connector behind that power port, remove the fuse and there are 2 small tabs to push in on, and it can be pulled out, make sure the key is off while doing this. This is the IP 1 Accessory Power outlet. But most of the time there is something stuck in it, or if you have a cigarette lighter in there, it might be worn out and shorting the circuit out.
Images (Click to enlarge)
Jul 24, 2023 at 6:46 AM
