cylinder 1 misfire
240,000 MILES
BARNABUS PALMATIER
Cylinder misfire, plug shows black. Changed plug, engine performance hiccups when accelerates then kicks in. Is plug fouling from too rich or need cleaning?
Jun 8, 2016 at 7:13 AM
WRENCHTECH
  • 20,760 POSTS
The blackened plug is fuel deposits. It can be either lack of spark or excessive fuel. That needs to be determined through testing.
Jun 8, 2016 at 7:45 AM
BARNABUS PALMATIER
The pressure at all four cylinders is 210. The plugs were all changed. Cylinder #2(fr left to right) had the fouled and (then?) blackened plug. The stuttering, hiccuping but especially weakened to near stall with acceleration at hairpin or very sharp turns is apparently recreating the same outcome wherein the second cylinder does not or only barely fires.
Jun 9, 2016 at 5:09 AM
  • 55,748 POSTS
Hey BARNABUS,
It sounds like you have a fuel injector that is stuck open or the spray pattern is bad, please remove the injector for testing, here are a couple guides that can help you
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
and
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Let me know how it goes.
Best, Ken
Jun 11, 2016 at 6:58 AM
BARNABUS PALMATIER
Will do.using your info. Get back to you, Ken.
Jun 11, 2016 at 11:50 AM
