On take off it cuts out and will not accelerate
2000 GMC JIMMY
178,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
CHRISTINA86
Will not accelerate unless I leave off the gas a little. Also, noticed when I pulled in last night that the headlights would flicker as well.
Aug 2, 2018 at 6:36 PM
Good morning.
The first thing I would do is check the fuel pressure. Make sure it is within specs.
Check the throttle body plate for any carbon build up as well. that will cause hesitation.
Have you ever had the injectors cleaned?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Aug 2, 2018 at 10:24 PM
