Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Jimmy
Engine
Symptoms
Low Power
On take off it cuts out and will not accelerate
2000 GMC JIMMY
178,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
CHRISTINA86
MEMBER
1 POST
Will not accelerate unless I leave off the gas a little. Also, noticed when I pulled in last night that the headlights would flicker as well.
Aug 2, 2018 at 6:36 PM
Experienced Mechanic
Good morning.
The first thing I would do is check the fuel pressure. Make sure it is within specs.
Check the throttle body plate for any carbon build up as well. that will cause hesitation.
Have you ever had the injectors cleaned?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Aug 2, 2018 at 10:24 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
