on start
112,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
GAILO
  • 9 POSTS
cranks on start on fire replaced dist coil &control modul
Jan 4, 2016 at 1:10 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Jan 4, 2016 at 1:30 AM
GAILO
  • 9 POSTS
no codes fuel pres good no fire
Jan 4, 2016 at 2:05 AM
HMAC300
  • 48,601 POSTS
what size engine and what system do you have ? ditributorless or tfvIV?
Jan 4, 2016 at 4:03 AM
GAILO
  • 9 POSTS
50 with tfvIv system
Jan 4, 2016 at 6:00 AM
HMAC300
  • 48,601 POSTS
see pics
Jan 4, 2016 at 7:44 AM
GAILO
  • 9 POSTS
my module is on fender not on dist
Jan 4, 2016 at 7:59 AM
HMAC300
  • 48,601 POSTS
doesn't matter tests same way
Jan 4, 2016 at 8:03 AM
HMAC300
  • 48,601 POSTS
one thing I did forget is to check fusible links that go off of starter relay shold have 12 volts each side wiggle them around when you test them.
Jan 4, 2016 at 8:08 AM
GAILO
  • 9 POSTS
thanks I ll checklater got dark on me
Jan 4, 2016 at 9:07 AM
CJ MEDEVAC
  • 11,000 POSTS
DIFFERENT GUY
WITH A VOLTMETER [PREFERRED](OR IN DESPERATION, A 12 VOLT TEST LIGHT MAY CONFIRM THERE IS POWER ANYWAY)
TEST THE POSITIVE SIDE OF YOUR COIL WITH THE KEY "ON"
THEN TEST IT AGAIN, WHILE YOU CRANK IT
ARE YOU GETTING "JUICE" IN BOTH SITUATIONS?
ALTHOUGH THE PICS I'M PROVIDING LOOKS NOTHING LIKE YOURS (IT'S OF MY '77 JEEP CJ-5) IT'S THE SAME SET-UP FOR THE VOLTMETER. DISREGARD THE "JEEP INFO" IN THE EXPLANATIONS.
AUTO PARTS STORES HAVE DIGITAL VOLTMETERS STARTING AT ABOUT $20, HARBOR FREIGHT HAS 'EM FOR ABOUT $5.
KEEP ON FEEDING THE BOTH OF US SOME FEEDBACK!
THE MEDIC
Jan 6, 2016 at 11:48 AM
GAILO
  • 9 POSTS
thanks for info let you know when I check it out
Jan 7, 2016 at 1:42 AM
