On acceleration car stall no revving
20,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
ABBAS ABOBAKER
Car v4 starts well and idles beautifully.but on acceleration she shuts off. Is it the carburetor or distributor?
May 9, 2017 at 6:15 AM
ABBAS ABOBAKER
Hi, need to know whether the condenser will cause car to idle only and cut off when trying to rev there is a flat spot as well. have set timing, good fuel supply, new points and plugs.
May 9, 2017 at 7:21 AM (Merged)
HMAC300
  • 48,601 POSTS
I kind of doubt it is the condenser but grounded points will do that . they will let the car idle but nothing else. also check ground in distributor to plate from housing.
May 10, 2017 at 5:25 AM
ABBAS ABOBAKER
Thanks very much much appreciated
May 17, 2017 at 4:10 PM
  • 55,684 POSTS
Cheers, Ken
May 20, 2017 at 12:46 PM
