What tools are needed to unscrew the two screws inside the door at the bottom of the window that's on the back drivers side
173,072 MILES • V6 • MANUAL
LEE BROWN
What type of tool is needed to unscrew the two screws inside the door at the bottom of the window that's on the back drivers side.
Car listed above is a GL model.
Oct 15, 2019 at 4:50 AM
We don't have a detailed manual that shows the screw sizes for each one. If you send me a picture of the screw I can tell you what type it is. I suspect it is a torx bit but seeing the head of it, I will know for sure. Thanks
Oct 15, 2019 at 9:29 AM
