Correct. However, I just want to correct the thinking just a bit.
OL means out of limits or infinite resistance. Which means there is so much resistance that the meter can't read it. That is different then no resistance or 0 ohms. You can actually have a circuit that has no resistance because the amount of resistance that is there is so low that the meter cannot read it and it will show 0.
When there is an open circuit/broken wire, then there is so much resistance that the voltage/current cannot flow.
I don't want to split hairs because your thinking is correct but just want to clarify that for anyone else in the future that reads this. Thanks for the update.
Apr 9, 2021 at 11:59 AM
