The oll was changed I think wrong oil filter was put on
99,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
WALKERSCOTT
The oll was changed I think wrong oil filter was put on now The oll pump is leaking
Feb 3, 2016 at 2:16 AM
WRENCHTECH
  • 20,760 POSTS
So, what is your question?
Feb 3, 2016 at 3:48 AM
WALKERSCOTT
Would that have caused it to leak
Feb 3, 2016 at 1:33 PM
  • 31,937 POSTS
Can you post the filter make and part No? An incorrect filter often will just leak oil from the seal or not fit at all.
Feb 3, 2016 at 3:11 PM
WRENCHTECH
  • 20,760 POSTS
There is a remote possibility if it caused the pressure to go extremely high but that is highly unlikely. That would be more of a defective filter than an incorrect one.
Feb 3, 2016 at 6:00 PM
WALKERSCOTT
Blow out the o'ring on the oll pump front housing caused by high pressure
Feb 3, 2016 at 9:39 PM
WALKERSCOTT
It fix
Feb 3, 2016 at 9:41 PM
WRENCHTECH
  • 20,760 POSTS
That could have just as easily been caused by overfilling the oil also.
Feb 3, 2016 at 9:53 PM
  • 31,937 POSTS
I agree, these engines have been known to have oil pump problems when they get some Km's on the clock, i do doubt that the oil filter was the cause of the problem,
Feb 4, 2016 at 4:33 AM
