1990 Oldsmobile Toronado No start condition
THEFIXER123
Computer problem
1990 Oldsmobile Toronado 6 cyl Front Wheel Drive Automatic
I have a 1990 Oldsmobile Tornado with a no start condition it's getting fuel and spark the crankshaft position sensor is less then a yr old and the camshaft position sensor is probably still the factory one my question is what are the specs on the camshaft sensor or is there another procedure used to test it because I think it's one of the sensors thats not delivering the correct comands to the computer.
Feb 5, 2010 at 4:19 AM
  • 75,988 POSTS
Next step is check the valve and ignition timing-If there's a problem with the cam and crank sensors you won't get spark and fuel
Feb 5, 2010 at 4:28 AM
