1990 Oldsmobile Toronado Brake lights
POETTER
The brake lights won't go off. Keeps running battery dead. Have to pull fuse when parked. How do you fix?
Feb 6, 2010 at 6:35 AM
  • 75,988 POSTS
Check and test the brake switch -follow the brake pedal arm to the brake pedal support bracket the switch is here.
Feb 6, 2010 at 6:40 AM
