2004 Oldsmobile Silhouette torque
88,560 MILES • 6 CYL • AWD • AUTOMATIC
GOBAMAGO
Have a torque pulland I need front struts and a front engine mount said the Mechanic; I am a lady, do I really need thisfixed?? I bought this car with 10,000 miles from a dealer and it pulled to Right then and it still pulls to Right; so it probably had this problem when I bought it in 2004. They have Rotated my Tires regugarly trying to fix problem. Is this Dangerous??? Going to Indiana from Alabama, do I need to worry??? Thenk you .
May 5, 2010 at 9:42 AM
TOOOMANYTOYS
  • 513 POSTS
Torque steer is when your in a straight line and accelerate from take off the vehicle pulls to the right. This is a normal operation. If your cruising or coasting and there is a pull you may need an alignment or you may have a worn component. Are the tires wearing uneven?
May 5, 2010 at 10:12 AM
