2004 Oldsmobile Silhouette geer shift on steering column
KARENKLIPSCOUPONS
2004 Oldsmobile Silhouette 87000 miles
I put my vehicle in drive & when I pulled int the parking space to park I could not shift to park. The light stayed on drive and the geer shift moved freely up and down instead of locking into place. What do you think caused that & how would you fix it?
Aug 26, 2010 at 11:49 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like your shift cable broke loose.Check the shift cable on the transmission and see if it's still attached.If it is then it probably came loose on the steering column.
Aug 26, 2010 at 1:12 PM
