2002 Oldsmobile Silhouette Water leaks
2002 OLDSMOBILE SILHOUETTE
125,000 MILES • 6 CYL • FWD • AUTOMATIC
HPENNINGTON
I am getting a lot of water on both the passenger and drivers side of the floor board. We have tired to unclog the drain hole and it appears to working. Lots of water comes out of it. Where else could the water be coming from?
Thanks,
Henry
Aug 16, 2010 at 3:46 PM
  • 31,937 POSTS
Hi there,
wind screen leaks and plenum chamber drains will also cause internal leaks if they are blocked.
mark (mhpautos)
Aug 16, 2010 at 7:50 PM
HPENNINGTON
Thanks Mhpautos,
Are those some what easy to unclog?
Thanks,
Henry
Aug 17, 2010 at 1:19 AM
  • 31,937 POSTS
If you run a hose over the wind screen, you should see the water drain off through the front vent and away under the car, you will have to look for the actual drain point as i am unsure where it is on that model. i will look into it and see if i can find a pic.
mark (mhpautos)
Aug 17, 2010 at 2:53 PM
