2001 Oldsmobile Silhouette Removing the passenger side stru
135,000 MILES • 6 CYL • FWD • AUTOMATIC
MSSAMLUK
  • 6 POSTS
I can not remove the passenger side strut bracket.
I removed the top bolt and backed out three other bolts, tthree on the ac compressor. Do I need to remove the radiaror? I have removed the cooling fans.
I have un-bolted the ac compressor. There is little movement of the bracket. Do I whack to with a hammer? All bolrs are removed, and it still won't move.
Aug 28, 2010 at 9:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating Below are the proper replacement steps, let me know if you need further assistance with this repair. .
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2635.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_860.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_312.jpg
Aug 28, 2010 at 9:52 AM
MSSAMLUK
  • 6 POSTS
Your answer was for the wrong strut. I am replacing my head gasket and I am having trouble removing the bracket on the engine, passenager side, that supports the engine to the frame. I have un-bolted the AC compressor and removed the two other bolts, but it will not come off. Do I have to just force it off, or are there other bolts that i missed?
Aug 29, 2010 at 5:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry, was thinking suspension. Before you can remove the right engine mount strut bracket you have to first remove the upper and lower intake manifolds. Have you removed these yet?
Aug 29, 2010 at 10:34 AM
