2001 Oldsmobile Silhouette rear lamps
140,000 MILES • 6 CYL • FWD • AUTOMATIC
TAWESGRAY
My passenger side rear lamp is acting up. Turn signal works fine until you press the brake, then the signal blinks at a sporadic rate. Also when you hit the brakes or have the tail lights on, both turn signals are constantly on, but dimly. When this happens, it occasionally knocks out the traction control as well.
Jun 26, 2010 at 1:41 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check wiring, seems like have ground wire issue at one of the lamp assemblies.
Jun 26, 2010 at 5:22 AM
