2001 Oldsmobile Silhouette Indicator
HEIDICID
Electrical problem
2001 Oldsmobile Silhouette 6 cyl Automatic 140000 miles
Engine temperature Indicator (needle) does not work, The car is ok, the vent that cools the car is working, everything seems to be working fine but the needle does not work.
Apr 1, 2010 at 4:44 AM
DOCFIXIT
  • 18,828 POSTS
Maybe faulty Engine Coolant Sensor
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_424.jpg
Pull connector and ground brifely if gague moves towards H then sensor if no then gague
Apr 1, 2010 at 5:07 AM
