2001 Oldsmobile Silhouette Heating issues
170,000 MILES • 6 CYL • FWD • AUTOMATIC
WHIPXX
Temp gauge will not climb above 1/4 and the heater
only blows warm air. When the outside temp is 10deg. or lower it will not stay warm inside. The intake gasket was replaced and the thermostat, but
we still have the same issue. Any help would be much
appreciated. Thank you in advance!
Sep 28, 2010 at 5:20 AM
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temp, locate the 2 heater
hoses where they go into the firewall and feel them to see if
they are both hot to the touch. If they are..........
The temperature is controlled by the use of an air mix door
that is operated by an electric motor/actuator. This door can be
jammed or the actuator can be inoperative or have stripped
plastic gears internally.
Sep 28, 2010 at 5:28 AM
