2000 Oldsmobile Silhouette Won't start
13,500 MILES • 6 CYL • FWD • AUTOMATIC
ANGELA_BAIER
My van won't start. When you turn the key the lights and everything comes on but it does nothing. Sometimes it clicks. We tried to jump it but- nothing. I have a fairly new battery in it. What could it be?
Sep 25, 2009 at 3:00 AM
JDL
  • 16,098 POSTS
Welcome to the forum, have you tried cranking in neutral? How do interior lites react with the key in the crank position? If they just stay bright, sounds like an open circuit to the starter. If the lites go out, you need to make sure the battery has a full charge and the connections are ok. If that checks out, my next thought is the starter itself. How did you try to jump the starter?
Sep 25, 2009 at 4:23 AM
ANGELA_BAIER
You were right, it was the starter! Thank you sooooo much!!!
Sep 25, 2009 at 9:11 AM
