2000 Oldsmobile Silhouette van is overheating
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
ELPELON
we have changed the thermostat, coolant sensor, water pump, the sensor says its overheating, and and it says low coolant but it has coolant, what else could it be?
Aug 28, 2010 at 4:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
low coolant sensor is different than the coolant temp. sensor . the low coolant sensor is located at the bottom of the coolant overflow tank. do you have any signs of overheating aside from the gauge reading?
Aug 28, 2010 at 5:13 AM
ELPELON
no steam comes out or anything, we think it has a clog in the radiator, maybe it needs a radiator flush, but its funny when it heats up the heater does not work. and the air conditioner lines get very cold
Aug 28, 2010 at 8:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the heater can't work if the engine is overheating, if the thermostat and water pump have already been replaced than it may very well be a clog in the system, perhaps the radiator or maybe even the heater core is clogged up.
Aug 28, 2010 at 9:34 AM
MSSAMLUK
  • 6 POSTS
Same problem as mine, it could be the head gasket.
Aug 28, 2010 at 10:57 AM
ELPELON
we flushed the radiator and it still does the same thing.
Sep 2, 2010 at 5:12 AM
