2000 Oldsmobile Silhouette replace driver pwr window regula
127,000 MILES • 6 CYL • FWD • AUTOMATIC
CNTR-OPER
I have a 2000 Silloeutte. the pwr driver side window goes up and jams and if pulled to straighten will open and close. I have taken the door panel apart. what I see pwred crossed members and one of the rivets or screws at pivot point have failed causing window to go up unevenly. My question is there is a strong compressed spring connected to regulator to help raise and lower window. Haynes manual mentions special tool to keep spring from fly loose when removing regulator section. What is tool or is there another way of safely locking spring mechanism?
Jun 29, 2010 at 7:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the special service tool needed to release the regulator spring tension is # J 38864 and is called a Door Module Coil Spring Tool.
Jun 29, 2010 at 11:43 PM
