2000 Oldsmobile Silhouette Pass Window will not go up
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
CCWEBPASTOR
We have been having problems with the passenger window on this van. We used to be able to wait a little bit and then the window would go up but now it won't go up at all,
Aug 18, 2009 at 2:06 PM
  • 110,248 POSTS
I need you to remove the door panel and expose the motor. Once you do that, use a test light or volt meter to make sure you are getting power to the motor. Keep in mind, there are two wires. One will get power when going down and the other when going up. If you are not getting power when going up, it is a switch problem and not the motor. If you are getting power, then the motor is bad.
Aug 18, 2009 at 4:20 PM
