2000 Oldsmobile Silhouette oil pressure
105,000 MILES • 6 CYL • FWD • AUTOMATIC
FORDMAN81
oil pressure light came on check oil it felt like water so i changed oil light still comes on but goes out in less than a second im leaning toward pressure switch but im not sure any ideas
Jan 2, 2009 at 9:08 AM
  • 75,988 POSTS
Sounds like your on the right track with the switch-if not check the oli pressure with a mechanical gauge and it will tell you something about the oil pump and engine bearings-
Jan 2, 2009 at 10:34 AM
