2000 Oldsmobile Silhouette hesitating
2000 OLDSMOBILE SILHOUETTE
CHRISINTAMPA1
Engine Performance problem
2000 Oldsmobile Silhouette 4 cyl Automatic 141000 miles
My vehicle hesitates when I step on the gas. It feels like it is going to stall , the RPM's jerk all over the place, sometimes it backfires, the change engine oil,sensor tracking etc lights pop on and off. If I let up on the gas sometimes its ok - other times it just gets worse. I usually have to pull over shut the car off and then restart it. There is no rhyme or reason as to why it is doing this or when it will do it. I have replaced the catalitic converter and plugs,wires, pvc valve - no one has the answer. Has anyone else had this problem? Seems to be fine the first 15 minutes of driving then acts up. I need help!!
Nov 1, 2009 at 1:05 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect fuel pump and fuel pressure
check fuel pressure and do a fuel flow test
also do you get a check engine light on ?
check for codes
check coils if firing at all cylinders and all the times
under load
Nov 2, 2009 at 6:32 AM
