1999 Oldsmobile Silhouette Thermostat or water pump
17,000 MILES • 6 CYL • FWD • AUTOMATIC
CAMARO6079
The water temp. gauge will suddenly and quickly move to the hot side and then after a few seconds it will quickly move back to the cool side and stay for a while and then repeat. I believe it is the thermostat, it is not loosing coolent or overheating, in fact it takes quite awhile to get heat from the heater
Mar 1, 2009 at 11:26 PM
2CARPRO JACK
  • 11,533 POSTS
Usually sudden spikes are a sticky thermostat.I would start there.If the level is full then that would be the place to begin, water pumps dont work then stop working
Mar 1, 2009 at 11:31 PM
