1999 Oldsmobile Silhouette Rough Idle, Occasional rough sta
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
IVARUSSELL
I have a high mileage car that I would like to keep for as long as possible.
My car will occasionally have huge issues upon start-up if I haven't driven it in over a day. It will run rough, buck and threaten to stall then after a few minutes of running, it will all of sudden "catch" and work fine from there on out. It is almost like it needs its morning coffee.
I have changed the O2 sensor, plugs/wires, fuel filter and do regular oil changes. However, at one point after a trip my oil dropped to the point that the light came on.
Lastly, my transmission fluid seems to need replaced alot these days.
Help![img:360f0f0c9d]http://www.2carpros.com/forum/automotive_pictures/401856_s731948732_1175075_9769_1.jpg[/img:360f0f0c9d]
Aug 27, 2009 at 9:07 AM
  • 75,988 POSTS
Clean out the idle air control valve and test the TPS and MAP sensors.
Aug 27, 2009 at 2:23 PM
