1999 Oldsmobile Silhouette ABS adn Traction Control Light o
123,000 MILES • 6 CYL • FWD • AUTOMATIC
LCARTER5
Hi Recently my abs and traction control light came on my car. Also in 2007, I had this same problem, also that when I turn the right blinker on, it doesn't come on in the back and also when it is dark and the lights are on, my hazards come on when I turn or brake. They replaced a multi-function switch in 2007. What is up now, was that a bad switch?
Nov 9, 2008 at 1:48 AM
KENSEELEXY
Hi, I was wondering if you had found out what was causing this? I am having the same problem, and when the lights come on it seems to affect the transmission.
May 22, 2009 at 2:01 PM
