1998 Oldsmobile Silhouette Starts then stalls
1998 OLDSMOBILE SILHOUETTE
195,000 MILES • 6 CYL • 2WD • AUTOMATIC
TITANIUMRIDER
This weekend I installed an inline block heater and battery heater on my Silhouette (in preparation for Alaska winter). The inline heater I just spliced into the lower radiator hose and then I removed the battery to install the heater pad under it. The battery may have been disconnected an hour or so. Upon reinstalling the battery, I went to start the car and in the key first position, my idiot lights all blink on and off and when I start the car, it starts but then immediately stalls. According to my manual, this could be a vacuum problem or ignition problem. But since I didn't touch any of those items, I can't see how it could be them. Also, I just installed a new starter a month ago, and the battery is a 4 month old Interstate. There is some funny clicking in the relays at the engine fuse box, don't know if maybe one of those got shorted or something? Do you have any ideas? Prior to yesterday's work, the van was running great, even with all of its's miles. The only thing I know I did in the install is to get some coolant on the engine near the lower pulley, when I cut the hose. Other than that, the work I did was pretty straightforward and non-invasive.
Sep 19, 2010 at 12:06 PM
Can you keep idling while stepping on the gas pedal-if so The idle air control valve has to relearn the idle speed -
Sep 19, 2010 at 12:17 PM
TITANIUMRIDER
I tried several times to keep it running with the gas pedal, to no avail. I read about the PCM needing to relearn but haven't been able to keep it running long enuf for this. I've probably started it 8 or 10 times (let it dry out from the coolant and tried again today) and it does the same thing. Makes me think there is some kind of fuel shut off theft deterrent, but I can find no info on that.
Sep 19, 2010 at 12:29 PM
Do you hear the fuel pump come for a few secs? If so check the fuel pressure if its within specs-the specs is 41-47psi
Sep 19, 2010 at 12:35 PM
TITANIUMRIDER
Yes, I hear the fuel pump. Unfortunately, I am not a mechanic and wouldn't know how to check the pressure. I live 20 miles from the nearest garage and would have to pay to have it towed so was trying to get it running myself. What would have changed the fuel pump pressure with the minimal work I did?
Sep 19, 2010 at 12:48 PM
If it keeps stalling while your foot on the gas-it seems like its not getting fuel, open one or 2 sparkplugs and look/smell for gas-let me know
Sep 19, 2010 at 4:04 PM
