Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Silhouette
Steering
Tie Rod End
Replace/Remove
1998 Oldsmobile Silhouette Location of tierod clamp
1998 OLDSMOBILE SILHOUETTE
200,520 MILES • 6 CYL • FWD • AUTOMATIC
NORMANB124
MEMBER
1 POST
Installed new tie rod end where is clamp located to adjust toe in is it under boot.
Jun 29, 2010 at 7:17 AM
DOCFIXIT
Experienced Mechanic
You must be old like me no clamp you loosen the nut at tie rod end rotate rod
Jun 29, 2010 at 8:29 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
