Engine Performance problem
1998 Oldsmobile Silhouette 6 cyl Two Wheel Drive Automatic 139.00 miles
I HAD TO REPLACE A BLOWN HEAD GASKET. NOW THAT ITS ALL BACK TOGETHER THE ENGINE WILL RUN UNTIL IT GETS WARM THEN THE VAN JUST QUITS RUNNING. I REPLACED ALL VACUUM LINES AND TPS AND IDLE FLOW SENSORS, BUT IT STILL STALLS WHEN IT GETS WARMED UP. CAN YOU TELL ME WHY?
Feb 12, 2009 at 11:32 AM
